deviousKA wrote:i would like to offer ka24de destroked and fully counterweighted shortblocks. development continues. i will have site up soon but right now i only offer ka24e stuff, which includes high comp. piston kits, and possibly solid/adjustable rocker conversion, both require a core to be sent in. ill see what i can do for the low compression ka24de needs as far as pistons, but im sure people will be interested in my destrokers. i need to find a source of KA20 crankshafts
Motorworks, Orofino, ID
deviousKA wrote:yes that negates the ability of using ka rods, the information in that thread does not give me any reason not to continue my process. we will see how it goes.
if it is totally impossible, there is still possibility of using a l/z block, which could be stronger anyway.
cnichols wrote:"The KA engine is different than the L Series. Both rod and Mains are different than the L-Series. None of the L-Series cranks will fit either of the KA blocks (truck or 240SX).
Not only are the rod shells narrower but the locking tab is on the opposite side from the L-Series rod. The rear crank register of the KA motor is different than the L-Series. All of the work done here on the KA engines was done with the OE crank. I do not know of any other crank that will fit in the KA blocks. "
Steve Christiansen (Nissan Motorsports)
Taken from a thread on Fresh Alloy...an e-mail in reply to Demetrius (demcj on NICO).
*They had a discussion about this over a year ago.
But good luck anyways...you might find something they missed.
