Lokim wrote:That code is for the solenoid, not the MAP or BARO sensor. Find the harness pins for it at the ECU or elsewhere. Apply Battery voltage. If the solenoid clicks, reverse the vacuum lines on the solenoid. If not, make sure it is plugged in, and if it is, its likely a bad solenoid.
Thanks for the battery voltage input. As for the code, you're right, it's not a sensor, it's a solenoid that dictates whether vacuum is given to the MAP sensor or not.
Here's the thing, this code came after an engine swap so I am suspect to a mistake of mine during installation.
Today I remembered a ground on one of the sides of the block had ground to dust, and was gone.
THEN, I decided to pull codes again. Well, it's been a few hundred miles since I first posted this (and had cleared the ECM), I have a few more codes....
a total of 12 codes, WOW. Quite a bit for a car that feels to be running at 95%.
So......I think I'll have a look at that ground, and see if I can tap out the rusted screw and reground it. I now have o2 sensor codes and even all of these:
p1490
p1110
p1492
p0135
p0446
p0155
p1400
p1105
p1145
p1490 PD
p1110 PD
p1492 PD
I'm starting to think this ground was critical to the harness and I have a ton of error codes as a result. Do you guys think this sounds reasonable? I had some of these codes before the swap, when the ground was so frail it had all but crumbled to dust. When I touched it, it disintegrated. This might explain all of it.
