huguetpj »
https://forums.nicoclub.com/huguetpj-u637.html
Tue Aug 17, 2004 7:42 am
Don't know much about MAP sensors, but I do have an EE degree and love DIY stuff... so I'll chime in.
First off.... materials. Microprocessor, either with internal or external ROM for the correction map. Does the MAP sensor require a control circuit (kinda like a WB02 sensor)? Couple of regs, maybe just one. Potentiometer... or much better have the uP have some serial connection to the PC for tuning... not that hard anyway.
Now... here comes the problemas I see. You would need the MAP's and IAT's response curves... you could possibly get that from datasheets... possibly. You would need to match one to the other into some kind of 3d map. X = T, Y = P, Z = Air flow. It ain't difficult, just a couple of equations I believe could solve that but I would need to look into the response curves to be sure.
Tha biggest issue is the original MAF's response curve. You won't get that easily. To get it you would need some kinda of test equipment to pass a measured amount of air/sec through the MAF to get the voltage returned and from there get the response curve.
If you get all 3 response curves all you would need to do is find the linear equation that would convert one (3d based) into the other (2d based) and program this "map" into the microprocessor. The uP would just read the IAT and MAP, resolve the equation and output the correct MAF voltage.
