Cone Junky wrote:Make sure the tensioner assembly is mounted at the exact same angle as the car it came out of. If it is tilted, the locking mechanism will not work properly.
/\/\/\/\- What he just said also, That bracket seems as if it would throw it off balance.
Pay no mind to the confusing question, sometimes i have trouble trying to somethings over the internet. My apologies.
And of course i do not mind you asking me how much i paid. It was 200+ shipping, A-pillars, B-pillars, Courtesy handle (Pansy Handle jk jk), Seat belts assemblies, And all hardware. Everything mounts up in stock positions and everything, IE: Holes and slots. Only problem is that seeing as how the courtesy handle is on the driver side (Because our cars are LHD) and the holes are not threaded for the hardware supplied. Therefor a tap/dye set is very nice when you get around to installing everything.
The handle after installation.
This is the bracket that holds the handle. The holes that you mount this part on are the ones that need to be threaded.
The last draw back to this setup is the gap it makes. Because as you probably figured out the automatic seat belts need room from the A-pillar to work so the A-pillars are mounted on brackets, which makes the USDM headliner cut shorter to accommodate for the space needed. Easy fix is to extend some fabric or just get a JDM headliner.
Oh and buy ALL my JDM stuff from Pandagarage
