Making the RB26dett transmission rwd instead of awd.
zenkisx
Car: Zenki 1996 240sx
Is it possible to disengage the AWD ability of the Rb26 transmission by removing the front drive shaft and the front drive chain and then removing the clutch plate? If not, would the best thing to do be to make a female adapter for the transmission's male end and just run a shaft from the transmission through the transfercase to the output after removing all the transfer case internals?
MS180SX
Car: 1989 Hatch- Crushed
1993 Hatch- Sold
2004 350z- wrecked
2005 STI- sold
2003 CBR 954RR- Sold
2005 Chevy Colorado- Sold
1972 Chevy Nova- Gas eater
to make the rb26dett just rear wheel drive, i think alot of people use the rb25det transmission.. supposedly it mounts right up, no problems...
JeromeS13
Car: 2008 Subaru Impreza STI
You'll also need an RB25 oil pan.
For more information on the CORRECT way do to this, see http://www.buwaldahybrids.com/speed.htm
-Jerome
Valley
Car: 00 celica gt-s 89 240sx hatch
people have done it, but it required cutting off the awd output and welding a plate in place as well as other stuff, i cannot recall the post name off the top of my head but search for it... it is there
Joe
yes it has been discussed but unless you have a really good shop willing to do it or know a ton about it yourself its alot easier to just spend the money and get a 25 transmission.
zenkisx
I agree that it would for sure be easier to do a transmission swap and use the RB25 transmission, but its money that could be spent on something more fun considering that I would much rather have a close ratio 6 speed than a 5 speed. I have the University of Florida's shop at my disposal so I think that it would be a fun project. and I know I'll still need the oil pan.
Another thing to think about, everyone says to just swap the Rb25det transmission, but what about the atessa system? The ECU for the 26 should read a malfunction when atessa isn't hooked up, how have you guys gotten around this problem?
zenkisx
oh and Jerome, considering that the rb25det transmission was never meant to be on the 26, and that the 26 was never meant to be rwd, i don't think there is such a thing as a CORRECT way to do it, just different methods of achieving the same goal
zenkisx
Kamin, I am in love with your car, nice job looks awesome and thanks for the input
Joe
zenkisx wrote:I agree that it would for sure be easier to do a transmission swap and use the RB25 transmission, but its money that could be spent on something more fun considering that I would much rather have a close ratio 6 speed than a 5 speed. I have the University of Florida's shop at my disposal so I think that it would be a fun project. and I know I'll still need the oil pan.
attesta is the least of your worries doing a 26 swap haha. dont even worry about it.
and thank you, i love my car too
driftjunke
We did it, it's not worth the trouble, save yourself time and headache's and get a 25 transmission.
E
slow s13
Car: cars, photo, music
when you put a 25 transmission on the 26 what else is needed? flywheel?
Toshima
Car: 93 240sx, 93 sc300(m/t)
This most likely wont help but I have heard of people swaping EVO 5 engines and trannys into mirages. By doing the same thing you said and just running the AWD transmission on a front wheel drive setup. They welded the rear end part shut.
Nerd_Juice
Car: 1992 Nissan 240SX SE
What about a Nissan 350Z transmission? Would it work? You would probably need some sort of adapting plate, but I figure it might work.
themadscientist
The RB25 transmission will bolt right up. You could just use an RWD oil pan rather than hacking up a 26 diff/pan.
