hi to everybody.
I have and issue with my just recently installed Magnaflow cat. conv. I have 06 G35 seda 6 MT. The car is california spec. But because I live outside USA in EU that is not an issue. But because I made mistake and brought my car 49 state version of cat conv. and the flanges are different from calif. spec.
Whe I found out it was too late to do anything and I did not wanted to send them back I decided to use my old OEM flanges that were welded to my new 49 state spec cat. conv. I am using OEM gaskets but there is still leak on exhaust and I have checked it several times no leak. But I can smell the leak in car.
There was said from magnaflow I cannot use 49 state version on california spec car? Why not? If there is difference in flanges, it is not problem but now I hear there is different gas sirculation, is that possible fix?
How can this cause exhaust gases leak if there is no visible leak?
What is the difference that I cannot use it with no problems?
