IMPORTANT: Every automotive repair and modification manual, experienced auto mechanic, and car enthusiast will tell you to disconnect the negative battery terminal before starting any work on your vehicle. It is a safety precaution that will help keep you from getting shocked and, possibly more importantly, will keep you from damaging your vehicle's electrical system. The negative is the electrical systems ground and is represented by "-" or minus symbol and is usually black in color (red is positive). Disconnect the negative battery terminal before starting any electrical work on your vehicle.
Front Turn Signals & Resistors
Left
Right
Rear Turn Signals & Resistors
Left LED, Right incandescent
Front Dome - Dual 12-SMD per side
Vanity Mirror Light - I suggest using less then 6-SMD bulbs. These are too bright and had to be rotated to lessen the light output.
Much more to come.
