MOWellsinVA »
https://forums.nicoclub.com/mowellsinva-u168807.html
Wed May 01, 2013 6:21 pm
My sunroof recently decided that it does not feel like closing properly anymore! It will start to close, gets about one-fourth closed, or even two-third closed, and decides to stop and reverse to open again. Once this happens I have to press the close button several times to get the sunroof to close in small increments. Once it is closed all the way I can reset by holding down the close button for a couple of seconds. However, after opening normally, most times now it will refuse to close normally.
I have cleaned all of track area and made sure to add some white lithium grease to the track mechanism, and I can't see that there is anything physically jamming the sunroof, but it seems that whatever safety sensor that prevents the motor from closing hard on your fingers or other appendages is too sensitive. Has anyone had this issue, and what kind of repair might be needed?
