Lubricating locks and hinges
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I know this seems really mundane and basic, but has anybody ever bothered to lube locks and hinges? I got some lithium soap based grease (in an aerosol spray can) as the owner's manual states and will lubricate areas per the FSM. I'm not having any issues with squeaky hinges or doors, but it doesn't hurt to do I guess. I assume I need to clean off the old grease and then spray on some new?
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
would you paint over a dirty surface? id say same rule applies. How would new lube get to the hinge if old muddy dusty lube blocks it? I say clean it. I was looking at my hinges today too and it looks pretty grimey.... now that you mention it ill most likely tackle it with degreaser and clean it up.
Towncivilian
Yep, figured as much. Just need to find some degreaser (might just try some dish soap :gapteeth:) and I'll be set!
Innovazn
Towncivilian wrote:Yep, figured as much. Just need to find some degreaser (might just try some dish soap :gapteeth:) and I'll be set!
wax and grease remover is your best friend.
Towncivilian
Guess I can go pick some of that up, NAPA's only a short drive away. Probably'll work better, anyway.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Put a little Gunk on a paper towel.
Chuck
Innovazn
Towncivilian wrote:Guess I can go pick some of that up, NAPA's only a short drive away. Probably'll work better, anyway.
works wonders on EVERY thing...... i clean my rims with it once in a while... but gotta be fast, cant let it dry. one wheel at a time. be surprised what kinda crap comes off em... even the rubber on the wheels too... gotta get the old tire shine out after a few applications.
ARKQX33V6
WD 40 spray on wipe off its cheap, cleans old grease and water proof surface takes white lithium.
Towncivilian
Did this earlier today. Cleaned off any old grease using WD40, worked perfectly. I applied the aerosol grease liberally and wiped off excess. Didn't seem to have a marked improvement, but I was not having issues in the first place.
I also lubed up a buddy's 1991 Dodge Caravan van's locks, hinges, and door tracks and it solved a squeaky door hinge and made the sliding door smoother.
Towncivilian
Does the accelerator pedal need to be regreased ever?
Mine looks fine, I'm just wondering.
