No longer will you have to piece your kit together from various sources. You can get everything you need under one roof.
Kits can be purchased from directly us or from Sikky.
http://www.wiringspecialties.com/coswki.html or http://sikky.com/mount_kits_high_perfor ... cturer.php
Kit comes standard with:
- Wiring Harness
- Motor Mounts
- Trans Mounts
- Driveshaft
- Headers
- PS Lines
Additional items can be added to your kit like an AC kit, clutch master cylinder upgrade, PCM flash, aluminum driveshaft upgrade, solid mount upgrade and more!
Stay tuned for future updates about this kit as more bolt on pieces are being developed.
Turn Key kits are also in the works for the E30 BMW, 350Z and more!
