kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Mon Jan 28, 2013 12:37 pm
the G37 is kinda loud cold start up, if you look the RPMss will be a little above 1000 RMPs at cold start up. This, as i understand it, is to warm the Cats up on cold start up. (after about 30 secs the loud snarl of the engine should go away, and RPMs will slowly drop as car warms) If you havent already noticed as soon as you shift out of park from a cold start up the RMPs immediately drop to the normal 500-600 range. So if your friends car is only loud on a cold start up this is normal.
now if this is happening on a warm start up then you definately have a problem.
