My 120K report on the Y34.
I bought this vehicle used at 44K miles in 2008. Its former life was in New Orleans as a leased vehicle to a pharmaceutical organization. The Carfax was clean.
LIKE
No….wait…I love this car. I love it more since I added an exhaust cut out on it with a remote control switch. It sounds awesome and I can open it or close it as needed.
I happen to get 21.6MPG on mostly highway driving every day. My commute is 28 miles at around 70MPH on average.
Style
It’s one of the most unique styles that Infiniti ever put on US soil and still one of the most unique on the road today among rounded econoboxes & homologous shapes that make me think "blah". It is the body style before the more rounded M models after the 2003-2004 (Y34) models. More information on the history of this body style can be found on wiki. It’s a good read about how it was first available only in Japan. You either love it or...love it.
It’s unique in that the doors are frameless, the passenger door still has cutouts for the trunk & fuel door release from the initial design as a right-hand drive car and the gas tank is positioned upright between the backseat & trunk. It came from the factory with a first aid kit in the rear arm rest. The trunk is also pretty big (to me). Some of those observations may not be noticed or liked by some, but it is fairly unique all the same.
Reliability
This car has been fantastic. No major breakdowns of any system, ever. It’s seemingly bulletproof in terms of how relaible it is. The one issue I happened to have was not a major system issue but was significant in that the fuel gague stopped reading properly. I removed the sending unit from the fuel tank, repositioned the float and it has worked perfectly since. (There is also an official recall for this issue.)
Interior
The seats are comfortable and the leather on them is wearing nicely. DO NOT USE A CREAM CONDITIONER ON THEM. The seats are perforated leather so the conditioner seals the holes and will not come out for a year or more until it dries and only then some can be vacuumed out. The cooled seats rely on these holes to be effective.
The in-cabin air filter is pretty easy to change once you've done it once or twice. The cooled seats work best if the under-seat filters are clean.
DON’T LIKE (described below are PCV, Paint, radio, NAV, steering wheel cover, trunk, brakes, gearing, creaks)
PCV
It burns a little oil at start up. Even after the air/oil catch can was added to keep the PCV system from letting oil into the TB, it’s still burning a little. My catch can may be too small and is still letting some oil by.
Paint
The paint on the front bumper started to bubble and peel away severely. The bumper appears to have been re-painted once before. The reason for the repaint looks to have been from normal wear & tear and typical scratches from close parking. The paint on the rest of the car is still pretty good, but not great. The clear coating on the wheels is peeling in several places.
Blose – This is my 3rd Infiniti with a Blose system and thay all lacked bass & punch in each system. One (‘97 I30t) finally lost the ability to control volume and it came with no steering wheel controls. It sounds OK, but will not knock your socks off.
Upgrading the Y34 stereo is accomplished mainly by removal and refitment of a new system. The caveat is that in the Y34, the Blose is an integrated unit to the NAV, HVAC, general vehicle settings and other integrated systems like the CD changer. Replacement with a different audio system in the Y34 will most certainly cause integrated systems to not to be integrated any longer and likely render useless the steering wheel controls. In short, you’ve “got what you got” with no option to upgrade without serious compromises. There is a way to integrate an aux input for an MP3 player that requires some serious wiring modifications and require some dash & audio component disassembly to get to.
Leather
I’m disappointed in the leather on the steering wheel. It has peeled severely and looks like that of a Hyundai after 2 years. Some people have had success with a warranty claim on later versions (post Y34) of the M, however you “got what you got” on the Y34 by now. I added a steering wheel cover to mine years ago and I hate it, but I hate looking at the beat up leather even more.
Trunk
The struts that raise the trunk are under engineered and do not raise it high enough not to have the auto closing system grab it again once the interior door-mounted switch is pressed. It closes nearly the instant it opens, making the door-mounted trunk release useless. A fix is possible with a new lift strut that can be DIY but requires removal of the rear seat back and interior-to-the-trunk trim removal. (I've since replaced them both. It was easy.)
Brakes
I cannot find brakes that don’t warp in this car. I got a set of cryogenically frozen rotors at a significantly higher expense than even dimpled & slotted only to have them warp in about 15 months. I’ll go back with the EBC dimpled & slotted next time and expect to replace them again 2 or so years, depending on how hard I push them.
NAV
The current version is 6.9 and the update costs $99 as of this write up. The Y34 NAV system is not impressive and does not allow for playing DVDs and there are no hack modifications for the Y34 noted on this site. Not impressive does not necessarily mean not good. It works and does the job well enough. The NAV settings and interface are logical and fairly intuitive.
Gearing
Turning 3000 rpm at 70mph is just not normal for a V8 these days. A 6th gear would have been ideal, even if it meant it hunted between gears a little on the highway and an extra $2000 in purchase cost.
Conversely, keeping the 5 speed automatic transmission and simply changing the rear end gear ratio might adversely impact the great acceleration especially from 50-70.
Manual shifting could be a bit faster. It does still shift down in manual mode as needed. Manually shifting down is not possible unless the engine speed is under the rev limiter's preset limit.
Creaks/rattles
There’s a terrible rattle in the windsheild defroster vent that I cannot locate. It seems that many other Y34 units have this rattle. I’m not aware of a TSB for this.
Another creak is in the B pillar of the driver’s side. It is only apparent in turns or hard acceleration. As a Japanese model, this car was only available as a V6 and body reinforcements were added to put in the V8 as a US spec car. I suspect that one of these reinforcements located in the B pillar is loose, twists when the body is flexed or has broken. It may even be a piece of trim in that area moving as the body is flexed. I will probably not look for the real cause myself as it has not gotten worse and the car still feels super-tight at 120K miles.
General upkeep
I use 5w/30 Mobil 1 (syn) and Purolator Pure One filters every 3000 to 3200miles.
I rotate in clean air filters (OEM type) about every 6000 miles and just clean them until they don’t come clean any longer, then I toss & replace it and keep cycling them. I keep 3 in the cycle process. It’s easier than hunting down a retailer that carries it when I need one and I take more notice of the filter condition with this interval.
I have the transmission flushed annually or at 15 months. The rear end gear fluid is the same interval.
I did my spark plugs at 95K or so and there was an impressive performance from the old ones. The difference has probably diminished somewhat 11000 miles later but the plugs that came out were only 25K miles old and looked horrible.
I use the highest octane I can find in this car, no exceptions.
I keep 40lbs of pressure in the tires.
Mods
There are few that are possible with the Y34. If you want a little louder exhaust, one way is to tie open the secondary exhaust valve at the muffler. If you live in a warmer climate and want to get rid of super-heated liquid running through the throttle body, another is to bypass the coolant passages into the TB. A different muffler would probably do even better, just keep in mind there's easy way to have true dual exhaust on the Y34.
I added a remote-actuated exhaust cutout and it’s awesome. Really sounds cool. I used the Raceland unit with remote control.
This clip is what it sounds like but this is not my car:
http://www.youtube.com/watch?v=RIe_1w6i5ho
The butt-dyno tells me it pulls better at speed, but it may be a bit slower off the line.
I have removed my engine cover and left it off. I can more easily look for issues that way and have found no ill effects. At one time, I removed the plenum to the air box in attempt to remove airflow restrictions but found no difference in the butt-dyno. The stock air intake to the filter appears designed well enough that I left it on.
I’m not sure if the UpRev tuning system is available for this car. If it is, please post up the before/after results.
That’s my report…
