Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Altima suspension modifications!
Location of the top mounting bolt on rear shock
Postby thrj7040 » Tue May 08, 2012 6:32 am
I have a 2006 Altima 4 door Sedan. and am needing to replace the rear shocks, it is not a strut assembly. I am not able to locate the top mounting bolt. Can someone help me with the location and do I have to remove the rear seat to get to them? If anyone already has pictures, that would be helpful. It seems like it should be simple if I can get to the top bolt. Thanks in advance for any help.
thrj7040
Car: 2006 Nissan Altima SL
Re: Location of the top mounting bolt on rear shock
Postby AlexM. » Wed May 16, 2012 11:22 pm
Not sure what exactly you're talking about. Can you post some pics of the general area?
BC & MDU Coilovers // WORK VS-XX // Sponsored by Top Speed Pro-1
AlexM.
Car: 2010 2.5 Altima Coupe Super Black
Postby thrj7040 » Thu May 17, 2012 11:13 am
I need to locate the top mounting bolts for the rear shocks.
thrj7040
Postby mrodrig2 » Mon May 21, 2012 12:08 pm
No such thing as a 2006 Altima coupe. Either way, have you looked in the trunk beneath the lining?
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
Postby thrj7040 » Fri May 25, 2012 7:18 am
No access in the trunk. Someone said something about removing from underneath the wheel well
thrj7040
Postby AlexN09 » Mon May 28, 2012 9:50 pm
There is only a rear spring and it just sits in there with no mounting bolt? And you do not have a 2006 coupe! Maybe you're talking about a 2006 altima sedan?
If you really want help you should give everybody a lot more accurate information!
All OEM lighting replaced, 15% llumar tint, debadged, vinyl grill overlays, footwell leds, projector fogs, 3/10 Tail light overlays
Audio: Pioneer AppRadio, Fully active bi-amped front stage, Alpine type R 12 in custom enclosure
AlexN09
Car: 2011 Altima Coupe 2.5S
Postby thrj7040 » Tue May 29, 2012 7:23 am
That is correct, I do have a sedan! Not sure why I typed coupe. But there is a shock and a spring, they are separate. The Shock bolts somewhere at the top of the wheel well. I think I can remove the entire bracket from inside the wheel well. Looks like there are two nuts to remove on top, and the one bolt on the bottom. I am not replacing the spring at this time.
thrj7040
Return to Altima Suspension, Brakes, Rims and Tires
