Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Feb 22, 2013 2:03 pm
As far as a dent in the pan goes, it really matters where that dent is. The pickup sits near the front of the pan. Most motorsets I've gotten, the shipping company jacked the lower pan up, so I"ve had to take ball peens to them to push them back out. I usually go a little crazy and bubble them out a bit more than factory just for the extra clearance. Now, the pan sits close, but you've got some wiggle room on a dent. I would say if it's over 1/4" of a dent, then you got a problem, but a few mils isn't going to kill your motor outright. Just pull the lower pan and bang the dent out.
SRs are quite noisy motors for head noise. Even after bleeding, mine begins to make a lot of tapping at idle within a few days. Pretty sure I just have some bad lifters, but I'm not gonna worry about it too much right now. The plan will be to convert to solid lifters in the future.
And as for the filter, K&N HP-1003s will fit as they're meant for SR20s. The book obviously only lists the SE-R, but an SR is an SR no matter the way it's mounted in this case. Usually I use HP-2008s as they're a bit bigger, but all of the local parts stores stopped carrying them for some reason. K&N still has them listed on the site, and the book still has them listed too. But the staff at the stores have no explanation why they're no longer in stock :\
