fueler »
https://forums.nicoclub.com/fueler-u54519.html
Wed Jan 15, 2014 7:35 pm
rather than splice into the signal stalk, why not tap the wire at the fuse box? Or, at worst, use an ohm meter to find the correct wire, using the highbeam wire at the interior fusebox ...
Personally, if I were you, i'd wire the lightbar independent of any other lights (so, on its own switch).
