I've been playing around with some LED bulbs for the Q. I'm running some "60W" bulbs like this in the front They're available for about $40 a pair on eBay shipped from China:
I actually ordered the rears before I found the "60W" bulbs. They're "11W" bulbs available for about $27 a pair shipped from China.
I think they're an improvement to the OEM bulbs. Certainly in response time - and they're finally as bright or a little brighter than traditional incandescent bulbs - which is saying a lot for aftermarket LED bulbs. Because LEDs are so directional - we're just now getting to the point that you can overload a traditional fixture designed for incandescent light that spreads roughly in a globe shape - with very bright more directional LED light.
You might notice that I put the wattages of the LED bulbs in quotes. That's because the sellers are listing these at the absolute highest wattage the LED will work at for some very short period of time before it burns out. In practice the LEDs are regulated to consume a fraction of the current of their rated capacity. So for our "60W" LED they're using 12 "5W Cree LEDs. Four forward facing and 8 around the edges.
Here are my measurements for all of the bulbs I'm using. The point is that a "60W LED isn't in any way a danger to pulling too much current vs. the stock 22W bulb. You'll also have to change the stock flasher for the turn signals, and deal with the "bulb out" dash warnings - even with the higher powered bulbs. Note that I didn't list a low+high reading for the LED bulbs. That's because they pull the same current as in the "high" mode.
LED "11W" 1157:
Low = 39 mA (0.47 W)
High = 139 mA (1.67 W)
LED "60W" 1157:
Low = 71 mA (0.85 W)
High = 271 mA (3.25 W)
Incandescent 1157"
Low = 460 mA (05.52W)
High = 1590 mA (19.08W)
Low + High = 1900 mA (22.8W)
http://youtu.be/wQdOzikPVTE
Front Signals - Full Sun - Leds on right of screen.
http://youtu.be/ZG7yRhQiUWA
Front Signals in the Shade
http://youtu.be/XJAfAATPkec
Rear Signals Full Sun - LEDs on Left of screen.
Park Lights - LEDs on right of screen.
Tail Lights - Full Sun - LEDs on right of screen.
Brake Lights - Full Sun - LEDs on right of screen.
Tail Lights - Shade - LEDs on right of screen.
Brake Lights - Shade - LEDS on right of screen.
One thing I'm noticing is that the greater brightness difference of the LED bulbs grows exponentially with dimmer ambient light. In other words they look "damn that's brighter" at night and only "maybe they're a little brighter" in full sun. I wonder of that has something to do with the fact that LEDs only emit a particular color wavelength vs. incandescent bulbs that fire off a broader spectrum of light?
I need to buy another pair of the rear red bulbs... I'm still debating getting 4 of the "60W" units vs. just adding another pair of the 11w ones. The challenge on the rear lights on the Q is that you're looking at the side of the bulb vs. the end. So the forward facing bright Cree LEDs are kind of wasted except that they tend to create a "hot spot" on whatever part of the lens they're hitting. I was able to bend the sockets to face forward a bit and that helped some...
I'm still looking for decent 921s for the third brake light (CHMSL) - but that's been a challenge so far. The ones I've ordered so far have been much too dim. One pair made it to the rear side markers and look good there though. I may have to make something.
Heath
