chipahoy »
https://forums.nicoclub.com/chipahoy-u191989.html
Thu Dec 22, 2016 8:49 am
Like anything else on the Q45, it requires a great deal of patience and tenacity. So far, changing the starter and power steering rack has been my toughest job. Anyway, the first time I changed the valve cover gaskets on my '99 Q45t i thought i was going to lose it. Unbelievable. It took me the better part of two days, then one side leaked and i had to remove it and redo it. Something I have learned after doing this several dozen times, on my car and others, is forget what Nissan tells you about only using the grey Nissan approved permatex, and to only use it on the half moon cut outs in the back. That is BS. If you follow Nissan's process, you will be changing the gaskets again in two years after the gasket by itself gets brittle and breaks. You have to supplement the seal. I have come up with a combination/process that almost insures your valve cover gaskets will not leak, especially if you are missing (broken) a bolt or two. If you are missing a bolt, use Pro Seal Copper XS Hi-Temp RTV Silicone Instant Gasket Maker on both sides (cylinder head and valve cover) of that area. The stuff is amazing. Everywhere else, on both the gasket and head, use Permatex 80062 Super High Tack Gasket Sealant. Bolt the valve cover back on as prescribed in the manual; let it sit overnight before starting the car to give the sealants a chance to dry. The Copper XS high temp is very effective and impervious to heat and oil and will seal where you are missing the bolt. Copper XS is used on turbocharged engines, stays flexible, and designed not to fail under pressure. The last time I changed my valve cover gaskets, about a year ago, I broke off the very back valve cover bolt (the one between the two half moon valve cover cutouts). Man was I PO'ed. And, there is no way to get a drill back in there to remove the old screw and tap it. Upon reassembly, I coated both sides (cylinder head and valve cover) between the lower and upper rear valve cover bolts with the Copper XS; and used Permatex super tacky everywhere else, both sides. Then I bolted the valve cover back on, waited overnight, and it hasn't leaked in a year. so even if you are missing a screw or two and you cant get to it or just dont want to mess with it, try this process! Tip. Never use any gasket cement or sealer on the valve cover before pressing the gasket in place. That is a guaranteed leak (I know from experience).
