mac1183 »
https://forums.nicoclub.com/mac1183-u222410.html
Fri Sep 13, 2013 11:51 am
Theres a little more to it than matching up the gasket size. You better take a plug gauge and a pitch gauge with you to make sure you have the right bolt size and pitch. a 3/4" bolt filter wont correctly bolt up to an M12 bolt. Not trying to sound condescending, I just don't want to see someone walk into an auto zone and try to visually match up filters strictly by gasket size, lose a filter 4 miles down the road and blow up an engine.
The only one I have found in my internet searching with the same bolt size/thread pitch with substantially larger physical size/capacity than the m1-110 is the m1-207 (and its cross references).
But that filter appears to be elusive to find sitting on the shelf.
There is no such thing as having too much oil, or too cool an oil temp (so long as you are above the pour point). But there is such a thing as having too little oil capacity, or too hot an oil temp. I guess I don't understand the reservation to even think about moving to a higher capacity filter on a motor without an external oil cooler.
mac1183 on Mon Sep 30, 2013 8:59 am, edited 1 time in total.
