As others said it's not a nightmare, but it is a little more in depth than average maintenance and you'll need some metric tools.
Leave yourself a good couple days to do the job if you haven't done it before as you definitely want to take the time to get everything clean and right so you don't have leaks or the belt on wrong and have to do it all again. The belt is easy to get on right if you just line up the marks on the belt with the gear marks, you can't really go wrong.
Also, as you are doing it, probably a good idea to change rad hoses and drive belts as you don't want to revisit that soon after. Best thing to do is buy the kit that includes everything you need, depending on what was done last.
*Check your power steering hoses for leaks while the rad is out as it's much easier to change at this point.
Here is the tech link:
http://www.ttzd.com/tech/timingbelttech.html
Here's a link for parts, but other places sell it as well. Personally, the 120k kit is the one to get:
http://www.courtesyparts.com/z....html
Modified by Zwicked at 10:36 AM 2/5/2008
