maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Fri Jun 02, 2006 3:53 pm
Did you make sure that the carrier bearing bracket was reattached to the block? I've seen it before that if that bracket isn't remounted to the engine block, the bracket will slap the block on take off.
Do you hear the noise at constant cruising speed, acceration, deceleration, turning corners (left turn .vs right turn)?
