FSUDrifter wrote:ok so should I just run another wire from the black/white wire on harness plug to missing pin on KS plug? and reconnect then tape off the end of that insulation?
I've think I found my ks, and I think its a two wire but I'm not sure, you wanna just come over and take a look? I can give you directions.FSUDrifter wrote:can anyone else confirm the above diagram?
I just don't understand why there are 2 pins in the plug that connects to the KS if only one wire is needed.
Can someone just look at there KS real quick or take a pic or something? This is the last thing left to do on my car.
