jhong1226 wrote:It comes on about one month interval.
Check your fuel rack gasoline pressure it may be low then try to adjust your timing to retard a very few degrees watch it and then try to advance just beyond static normal and watch it. What gasoline are you using, if high test you may be fouling the engine with carbon. Try mixing a 1/2 can of seafoam in the fuel tank with a full tank of gas, do not over use the seafoam, better to mix a little many times than to have too much at a single time.
