Since it's a 93, upgrade to phase 2 injectors if you can (94-96 style). I pulled mine including the rail from a junk Q in a u pull it yard. I then had Deatschwerks refurbish and flow test all 8. All 8 and the newer style rail are now on my '92. The work great, even under boostGood time to replace the injectors. See the threads on BDM or SMP injectors. Cheap and good.
