Spie PK wrote:I replaced the knock sensor on my 2004 g35 and after putting everything back together my car won't start. It will try to turnover but won;t. I don't think I damaged anything during the process. Clueless as to what the problem could be. I tried to also replace the knock sensor harness as well but could not figure out how to disconnect the old one from the main ecu harness.
Why not try putting everything back the way it was before you started.
If the engine is cranking you need three items for the engine to start
1- Air so make sure the air filter is not clogged
2- Fuel so make sure the fuel pump is operating
3- Spark so make sure you are getting spark
There was a caller on Car Talk this past weekend that had a crank sensor problem and a failure there will cause no spark and no fuel pump operation
Telcoman
