mej30guy wrote:About my knock sensor grounding. Can I sand the bottom of it with 220 or higher grit, to get the surface even? Like I said, it looks like a little of the ks casing has overlapped the contact area. (the little copper ring around the surface) Maybe that's why I'm not getting a consistent ground.
I'm both sorry and happy to report that I don't have as much first-hand knowledge of the KS I'd like to have in this case, as mine hasn't failed...yet.
We should still determine what KS terminals/outer contact areas are connected to which and I am puzzled why the instructions don't simply call for checking the resistance between the two terminals, if in fact one of them is connected to ground/the other contact areas. I'm not sure if the Piezoelectric element can be damaged by too much voltage. Also, the center/brass mounting opening that a bolt runs through is clean, right?
Also, have you measured the resistance of your old unit that's still connected to your old sub-harness? Does an infinite resistance reading/open circuit indicate a bad KS or sub-harness? It would also be good to know that the terminals on all of the connectors are matching up correctly too. Since there's only one clip in the end of the sub-harness, is it connecting to the terminal that's yielding the good resistance reading?
