TeflonG35 »
https://forums.nicoclub.com/teflong35-u86725.html
Sat May 31, 2008 6:47 am
The plenum is also made of a different material then stock and seems to stay alot cooler. The website says 50 degrees cooler then the aluminum plenums. I believe that statement. After running the car hard for a long duration of time i can pop the hood and put my hand on the plenum and it is only warm to the touch. Now if you touch the stock plenum after the same run you might end up with some burns.
Only down side is that i wish it looked a little nicer.
