philipa_240sx wrote:It sounds like you are having 2 separate issues:
1) The Intellikey doesn't work. Possibly due to a dead battery.
2) The mechanical key won't turn in the ignition. Sometimes this is caused by the steering wheel not being in the straight ahead position... I would have to double check to see what my Rogue does.
I would start by replacing the battery in the Intellikey. Do you not have 2 Intellikey fobs? I know some only got one with their Rogue... not sure why.
Finally, any service or replacement of the intellikey can only be performed by a Nissan dealer. They are the only ones who have the programming tools change/add intellikeys.
Thanks for the response. Well, I changed the battery, and still nothing. It doesn't unlock, or even sense that it's in the car to turn the ignition. The mechanical key still doesn't work as well. And it's definitely not a steering lock; we've made sure of that.
To give a little more information, yes, she was given 2 key fobs. But the (dealer recommended) installer for the autostarter needed to use the other one in order for the autostarter to work. So apparently that one is mounted in the dash somewhere.
My guess is they needed to bypass the security somehow for the autostarter, so they needed to use the other fob to trick the vehicle? In any case, I guess it's possible that the battery has died in that fob. I suppose this could explain the mechanical key not working-- they may have had to reroute some of the ignition security in order for the autostarter to work correctly. This is just a guess though.
This is the only thing I could come up with for the mechanical and the intellikey not working.
