Since vacuum controlled, there is zero egr on acceleration and at idle [Vacuum cut off].
The egr dirt all comes from cruising at a steady rpm on highway.........
Most air filters even oem are nowhere good enough.............97-99.9% won't cut it................20 million revolutions in 30,000 miles is a lot of dirt.300,000+ CF...................300 grams of dirt is almost a pound from the finest filtration.
http://www.donaldson.com/en/fi...4.pdf
Unfortunately Nissan engineers cannot use multiple tandem filters due to the limits they would place on HP............Oem are not allowed to sacrifice more than 1.0 HP to air filtration..
If engine longevity [low ring wear] is a real concern multiple AIR filters with a nanotube decondary filter is what you want.
Because most of gas engine EGR is made up of nonabraive carbon particles, however in diesels the particles are different and more abrasive.
http://www.sae.org/technical/papers/2000-01-0925
The sulfur in the diesel fuel reacts with carbon making a more abrasive compound.
Still a egr soot filter couldn't hurt if you were trying to get 500,000 miles from engines.
