I have read through several threads pertaining to this particular problem but most of them stop short after someone has replaced an injector.
This is what I have done so far as for troubleshooting:
1. replaced spark plugs and wires. Cylinder #2 has spark.
2. Swapped injector #1 with Injector #2. Both injectors work when in the #1 cylinder, but I get nothing out of cylinder #2.
3. replaced injector plug at the harness, it gets about 13v at the clip when testing with multimeter, but idle doesn't change when plugged up to the injector.
4. Checked the ECU for corrosion, there was none, looked brand new in there.
Is there something else that I am missing that would keep the injector from pulsing or spraying fuel into the cylinder? The spark plug doesn't have gas on it when checking, but I do have spark.
I have a compression test kit but have not checked compression yet as it seems like an electrical problem to me. I have a timing light but have not checked timing yet either...
If anyone would care to chime in, it would be greatly appreciated. I drive this car like grandpa and am not hard on it in any way. The car has been great since I bought it in 2007. The KA has about 151k miles on it and thus far has been extremely reliable. I am by no means a master mechanic but I do have the aptitude to fix this myself before paying someone.
Thanks!
