Ka24det Build
FireCatcher19
Car: 1990 Nissan 240sx xe
Hello everyone, last night i received my ka24de longblock. It has a polished crank, brand new oem rods, arp rod pins, arp head bolts, arias 9:1 forged pistons, honed .20 over, cometic mls head gasket, new valves, and everything is cleaned professionally, I will start with pictures later tonight.
FireCatcher19
Welp i changed my mind on which route i am going to take. I really want a straight six so am gonna sell my new motor and save up for an RB25det and run a standalone ecu.
WDRacing
I'd swap in a V8 before I'd use the RB. More power, cheaper parts and just as easy of a swap, if not easier.
Just my .02
WD
SiDwAyZ240
Car: 95' SR Slayer, '02 LT Tahoe, '03 Chev Express is the DD
WD- Why are you against the RB. Is it because for the $2500 price tag of a RB26 you could have a serious V8 monster? I assumed that a stock RB would be compairable to a V8, but could easily surpass 1 with some added boost or a single turbo conversion.
WDRacing
Don't get me wrong, I'd take the RB all day over the KA. But if you're goal is right now, instant grin type of power the V8 simply can't be beat. Take any 350 with Vortec heads, which is most of them these days, and use a elcheapo dual plane intake manifold from Summit with a matching carb and light cam and you're going to have, at a bare minimum, 350 ft lbs of torque from throttle tip in. That's on a budget of probably $1500 for the motor, rebuild kit and go fast parts.
That's like launching a KA at 15psi of boost for a comparison.
I like the RB26 when it sits inside of a R32 GTR. Other then that, cost vs gain keeps me out of the RB field.
WD
