superDorifto wrote:You would need to hack a good 2-3 inches extra out of the upper intake runners, and seal the entire area off. I priced out a cooler that size, and it would be in the 50-150 range depending on brand. You would need two block off plates to seal against, similar to the sc to manifold adaptor plate.
all told with a pump and hoses/couplings/machine work/misc hardware I figure it will cost somewhere around $6-700 bucks...
A good meth kit like the sno-performance one will run much less. I might still try to take a swag at the plates, I have like 2 extra manifolds lying around, but my focus for the rest of the summer is getting my own kit up and running.
I stand corrected by myself. With a little bit of searching...literally putting "water to air intercooler," into google I found the frozenboostDOTcom.
Pretty reasonable priced, and their $275 kit is the perfect size. You would still need to do some fab to mate it to the intake, but for the same price as a meth injection kit you can have a custom set up that will not need to be refilled/run dry and wreck your motor.
I just picked up an EMS for my build, and I am seriously considering trying to fab this thing up...I've never welded aluminum before, but I have friends that have. Any thoughts?
I think with this mod pushing past 300whp with a supercharger is a reliable daily option...assuming the tune is dead nuts on.
