NISSAN240SX12 »
https://forums.nicoclub.com/nissan240sx12-u60440.html
Sun Jul 12, 2009 6:04 pm
As title states im having bit of a misfire issue. I suspect the fuel injectors as the problem. I have new fuel pump, filter and coolant temp sensor. I know the manual says that the ohm readings should be at 11 ohms. I took a reading of each injector. cylinder 1 = 12.1, 2 = 11.7, 3 = 11.9, 4 = 13.1 The engine was warmed up while taking the readings. would that make a differnce when checking the ohms? Are my ohms readings to high? Thanks!
