wattydchi wrote:You shouldn't have to adjust anything. It uses hydraulic lifters with solid shims that set the clearance. If for some reason you need to adjust it, I hate to be the one to tell you, but those shims are close to $10 a piece after tax. That can be expensive depending on how many you need. The KA24E needs to have the valve lash adjusted, but not the DE.
WRONG, it's the other way around. The KA24E SOHC uses hydraulic lifters; no other adjustment. The KA24DE DOHC uses solid lifters with replaceable shims for setting the valve stem clearance.
You can get shims from Courtesy Parts
http://www.courtesyparts.com/index.html cheaper then most Nissan dealers.
