So much of this is misinformation.Valdis wrote:For what it's worth.... I spoke with Greg Dupree a few days back and he told me to stay away from the JDM motors. According to Greg most of these engines come from automatic cars, since most cars in Japan are automatics, He then told me that the Japanese motors only have 280hp. From searching online I did find this:
"Domestic Japanese market cars claimed 280 PS (206 kW), as the Japanese automobile manufacturers were limited to that number."
So it looks to be true, the JDM motors are only 280hp... but a good option if you don't have ANY motor.. lol
My 1996 TT also only had 280hp stock, so that stinks (440hp now). I'm going to have to add cams to get past the VTC or I'll never be able to get past ~400whp, regardless of what turbos I put on it. The cams are smaller and won't flow enough air to get power beyond ~400whp.
What's misinforming about it? Giving the silence, I guess none of it is.NolimitZ32 wrote:So much of this is misinformation.Valdis wrote:For what it's worth.... I spoke with Greg Dupree a few days back and he told me to stay away from the JDM motors. According to Greg most of these engines come from automatic cars, since most cars in Japan are automatics, He then told me that the Japanese motors only have 280hp. From searching online I did find this:
As I said, call him to get yourself up to speed... Phone: 818-703-6272 & 818-435-2061... let us know what he says since I clearly didn't hear him correctlyAs for Greg Dupree, I know who he is, everyone here knows who he is everyone here also knows and admits that he has likely forgotten more about the Z32 than most of us know, perhaps myself included. What Greg may or may not have told you is not what you wrote here and I would bet that this is the issue we face.
You mean the 440hp I spoke about?Lastly I would really like to know what work has been done to your 96, ODBII Z32 to make you reach those numbers (this is where we figure out if you are a troll or not.)
No, that is why I'm going to the dyno as soon as I can drive my car without having to worry about the rear end whipping around the front of the car every time the turbos kick in.Ace2cool wrote:So.... You don't have dyno charts. Noted.
So what is it that you think I've misunderstood? When I spoke with Greg his exact words were "Stay away from JDM motors"...Ace2cool wrote:I agree that you may have misunderstood what Greg was saying.
The turbine housing is different to account for the parasitic losses in the autotragic, so spool is faster but top end suffers. That would be the case if that was the only modification, but auto transmission cars also had different camshafts so the powerband (at the flywheel) is nearly identical.NolimitZ32 wrote:In addition the difference between the AUTO and Manual engine are the turbos, nothing else, the smaller turbos were fitted to the Auto to preserve the auto trans as they are not as robust as the manuals, the autos do produce less power but when buying a used engine especially a JDM you should always go with new turbos (if you cant pay to play than the Z32 is wrong for you). The difference between the JDM and USDM engines is: The oil filter tree is on the opposite side.
BigTDogg (MA) wrote:STOP AGREEING WITH ME SO AGGRESSIVELY!!!!![]()
For the sake of this discussion, tell us why you would "Stay away from JDM ENGINES" ... you don't agree with what I've said, so I'm interested in knowing your reasons to stay away from them.NolimitZ32 wrote:Anyone will tell you to "Stay away from JDM ENGINES" No one will argue that, its the other stuff that was not exactly true.
What reasons would you give to stay away from them? I can see we all agree to stay away from these things, but we are bickering over "why". I think it would be a great help if people were to know why to stay away from them.Ace2cool wrote:We're saying we know Greg, and his advice to stay away from JDM engines is good, but I think you misunderstood his reasons for saying to do so.
So that goes right along with what I was saying about my 1996 and the ~400whp wall.-Most TT engine that come over from Japan have different cam profiles than US engines. US 5spd TT's have 248 intake cams and 248 exhaust cams. US Auto TT's have 240 intake cams and 248 exhaust cams. Now...the Japanese VG30DETT did not have different cams, its just a very large portion of the TT Z's sold over there were automatic so most motors that make their way over here have the 240 intake cams
BigTDogg (MA) wrote:JDM engines are always a bad idea. Always. Unless you 100% plan on rebuilding it, DO NOT waste your time on a JDM engine.
I'll separate the thread tomorrow when I have a mouse. I'm on my laptop now.
Welcome!ztruck wrote:hi im new here , how can i post some pictures of my project
Again, welcome, but you're not correct. The cylinder heads are exactly the same USDM to JDM, and the only difference in camshafts is related to Auto or Manual transmissions.ztruck wrote:if im correct the jdm engine has a bigger cam shafts an the cilinders head the ports are bigger, the stock cams on a z32 are 248 an in the jdm i think is close to 264 is like a stage 1 cams from a aftermarket cams, so the jdm engine will give you more horse power
All I wanna know is, where do people get this info?ztruck wrote:if im correct the jdm engine has a bigger cam shafts an the cilinders head the ports are bigger, the stock cams on a z32 are 248 an in the jdm i think is close to 264 is like a stage 1 cams from a aftermarket cams, so the jdm engine will give you more horse power
NolimitZ32 wrote:All I wanna know is, where do people get this info?
That's OK, we don't have emissions testing in KansasBlackWidowZ wrote:he means by changing the ecu and cams. basically making a 96 a 95 but if u do that it wont pass emissions.
