Found them! Thanks man.Towncivilian wrote:The tools should be under the rear seat. Check for them first, if you don't have them I'll dig up part numbers for the lug wrench and spare tire lowering extension. The OEM scissor jack will likely be quite expensive new, it may be better to look at a junkyard for all of these tools in fact.
Wow.Towncivilian wrote:I'm glad they're there. Check if you need to air up the spare, mine was at 4PSI when I started driving my Pathfinder.
