A floor jack, garage jack, or hydraulic floor jack are all words for the same thing. This is the item that will lift your car up off the ground for you. The function of this device is exactly the same as the jack you've got down next to the spare tire, except the floor jack is bigger and faster, and can lift the entire front of the car at once. Such a jack as I am talking about looks like this,
and I know how to use it:
You should
NEVER get underneath a car that is only supported by a floor jack, it's not stable enough. If you need to do work underneath the car you'll need to support the car with something more stable. This is where jack stands come in:
Jacks stands will hold the car, either in the front, back, or both, once you have raised it up with a jack.
My question has been,
where are people putting the jack stands on the Versa?
