jack point
jet lee
Car: 2008 nissan rogue
Does anyone know these is correct jack point ?
front
front
rear
Pescakl1
Car: 2008 Nissan Rogue SL FWD
Iridium Graphite
Yes, you are right.
Thanks for the pictures, that will help others.
desiguy
This is the one that I purchased from a local auto store. Would this work or would I end up damaging something when I jack it up.
Thx
The link is
http://www.canadiantire.ca/AST/browse/4 ... ?locale=en
philipa_240sx
No, you'll be fine with that.
1) Make sure the jack is well supported on concrete or asphalt.
2) Be sure you are centered.
3) Use jack stands for safety.
jet lee
Thanks everybody. appreciate
Pescakl1
Iridium Graphite
desiguy wrote:This is the one that I purchased from a local auto store. Would this work or would I end up damaging something when I jack it up.
Thx
The link is
You are good with that.
Just to inform you if you want to jack up the whole car (4 jack stands), start by lifting the front first, it is easier that way.
rapposm
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
i think that jack might be to small to lift some area's. if you lift the differential you will be ok- but if you lift other area's i think you will be just at the height threshold.
ImStricken06
2016 Kia Sorento
ImStricken wrote:i think that jack might be to small to lift some area's. if you lift the differential you will be ok- but if you lift other area's i think you will be just at the height threshold.
nope sorry- checked the numbers, and you will be fine. mine is the same height from harbor freight.
http://www.harborfreight.com/automotive ... 68048.html
Qashqai
I wonder if I should put a material that will prevent the metal of the car touches the metal of the jack. It can be a 1/4" rubber (like couple of layer of an old inner tube) or an old cutting board? I thought it may cause some rust issues in the future.
Qashqai
ImStricken06
2016 Kia Sorento
Qashqai wrote:I wonder if I should put a material that will prevent the metal of the car touches the metal of the jack. It can be a 1/4" rubber (like couple of layer of an old inner tube) or an old cutting board? I thought it may cause some rust issues in the future.
have you ever looked under a car? there is more rust than bare metal. you will never prevent rust from the undercarriage or its parts. its just the nature of the beast.
save your effort with this worthless task and focus on something more productive.
ImStricken06
2016 Kia Sorento
PS: i would avoid lifting ANY vehicle by the rear differential. you can bend the cover, you can snap parts, and cause flexing in area's that shouldnt be flexed. you can bend the cover and cause a leak. Plus the differential just wasn't built to hold up half the weight of the car from the diff.
dont be lazy and lift the whole rear of the car on the pumpkin. leave it alone, and do it right and you wont have to worry about possibly causing hundreds in repair.
TrevorK
Car: 11 Rogue SV FWD
I, and many others from what I have read, use a hockey puck between the jack and the car. It's made of vulcanized rubber so it's not going to break. Some people also use a piece of 2x4/2x6.
They also make purpose-built jack pads, but I am unsure they are universal.
darylzero
Car: 2026 Toyota 4Runner Sport Premium
Previous-Nissan Rogue 2009 SL AWD Premium Pkg.
If I want to use jack stands like these, http://www.sears.com/shc/s/p_10153_12605_00950159000P
What are the correct places to put them in the front of the car and back?
thanks
ImStricken06
2016 Kia Sorento
darylzero wrote:If I want to use jack stands like these, http://www.sears.com/shc/s/p_10153_12605_00950159000P
thanks
same spots as OEM jack points, along the so called "frame" folds. or on strong frame/k-frame spots/sub carriers, etc
darylzero
Danke
darylzero
Ok so I was testing this this morning because I was going to paint my calipers today but it has been raining all day :mad:
I got a set of 4 ton jack stands, these, http://www.sears.com/craftsman-professi ... ockType=G1
and because the top of it doesn't curve down enough I cannot put it where you would the scissor jack, so I was going to put it just inside that lip, you can see from this pic
So is that an ok place? or will it bend the metal under there?
ImStricken06
2016 Kia Sorento
i never understood why they continue to make one kind of jack-stands. its time to update the design for more use by uni-body cars.
the only way around it for now is adapters.
i would put that jack between the edges of the pinch-weld.
Return to “Rogue Forum”
