clemson99 wrote:GerryO,
I have the same issue of the fuel gauge drops fast for the 1st 50 miles as you descibed. Why is that? Also how often should o2 sensors be changed? I never had that done before.
I think part of it's related to the shape of the fuel tank, with it being slightly tapered near the top and also to the less sensitive upper portions of the conductive sensing mechanism that are fully submerged only when the tank is completely Full, a condition that doesn't last for long.
Last changed both O2 sensors at about 175K miles, after the CEL light started coming ON, upon slowing and after driving non-stop about 100 miles at freeway speeds. Believe the exhaust also starts to smell a bit funky when an O2 sensor is starting to fail.
Found driver side is easier to change than the passenger side, and had to use an old sensor to chase galled inner threads of the threaded reducer bushing (removed it along with the sensor) on the passenger side.
