Is this the orange wire needed to fix cold starts?
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
I'm a noob, so I wanted to make sure before I cut anything.
I read that there is an orange wire located right near the dash that needs to be wired to the ECU (pin 43?) in order to help crank the car in cold conditions.
Is this the right wire? If not please help.
Also.. exactly what pin is pin 43?
OKRB20DET
Car: 1990 S13 coupe
RB20DET ECU pinouts
1 Ign signal (power transistor) Cyl #12 Ign signal (power transistor) Cyl #53 Ign signal (power transistor) Cyl #35 engine. A/T control input signal (bt1)6 Sub electrical fan relay (engine temp switch)7 Tacometeter speed signal9 AC relay (AC cut signal)10 Ground (ign signal system)11 Ign signal (power transistor) Cyl #612 Ign signal (power transistor) Cyl #213 Ign signal (power transistor) Cyl #414 engine. a/t control input sigal (bt2)15 engine. a/t control input sigal (bt3)16 ECCS relay18 fuel pump relay19 Power steering switch20 Ground (ignition signal system)21(RX) Receive (control unit data reception)22 (TX) Transmit (data sent from control unit)23 Detonation sensor 1 (cyl 1-3)24 Detonation sensor 2 (cyl 4-6)26 Air flow meter ground27 Air flow meter intake air quantity signal28 Engine temp sensor29 Exhaust gas sensor30 Sensor ground (throttle sen, ENG temp)31 clock (synchronization signal)32 Monitor and check lamp (red)38 Throttle opening output41 Crank angle sensor (120degree signal)42 Crank angle sensor (1 degree signal)43 Ignition switch START signal44 Neutral switch45 Ignition switch (IGN)46 AC switch47 (CHK) Check (diagnosis activation)48 Throttle sensor power supply49 Control unit power supply50 Ground (control unit)51 Crank angle sensor (120 degree signal)52 Crank angle sensor (1 degree signal)53 Vehicle speed sensor54 Throttle valve switch (idle connection pt)56 Throttle sensor output signal57 Throttle valve switch power supply58 Battery power supply59 Control unit power supply60 Ground (control unit)101 Injector #1103 Injector #3104 Fuel pump terminal voltage control output105 Injector #2 107 Injector ground108 Injector ground109 Injector power supply110 Injector #5112 Injector #4114 Injector #6115 exhaust gas sensor heater ground116 injector ground
there no more "sdfg"
Modified by OKRB20DET at 3:50 PM 2/16/2006
AxiOn419
Thanks, I was looking for that..
but as for "sdfg"..?
OKRB20DET
Car: 1990 S13 coupe
wouldn't let me post a picture with out typing something and those are the letters that randomly got typed LOL!
AxiOn419
Ha, Thats what I figured. Thanks again. Do you know if thats the right wire?
OKRB20DET
Car: 1990 S13 coupe
i dont specifically know if THAT is the orange wire you need, cuz god seems to hate me and the devil always finds ways for me NOT to finish my RB swap, my motor still sits on the pallet it came on with the band around it still but theres the ecu pin outs and what all the #'s are
who would like to donate to my mount kit or mouts/xmember fund?
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
thats the right wire. I just took picture of where to splice it into. Will post as soon as photos transfer from camera.
Vkoslak
Take your orange one, and splice it into wire "b" on plug "P"
Note that the wire colors are different on the other side of the plug, if you dont have the side of the plug with the yellow blue striped wire, then use the yellow black stripe one on the other side.
If you're wondering where I got those letters from, then check this link out:http://s92978298.onlinehome.us/RB/GTR_plugs.pdf
if you have an s13, just ignore the s14 side and use the rb20det side. I matched it up prettty good using s13 FSM.
Good luck!
AxiOn419
Thanks a lot vkoslak. I appreciate that greatly. I do have an s13
AxiOn419
vkoslak, I just went outside and checked and I have no idea where those plugs are that you mentioned. Alls i really see are the wires that connect directly to the ECU. Any idea what color wire it is that runs to the ECU?
edit- I think I located pin 43 on the ecu and it is indeed a yellow/black wire running to it, so just splice it into that and i am good to go?
Modified by AxiOn419 at 9:48 PM 2/16/2006
Vkoslak
Yeah, that should work. Those plugs are inside the car next to the ecu. Unless your motor importer cut them off.
AxiOn419
I believe they did cut them off, I'm pretty sure thats the right wire so I will tap it into that. Thanks
