The00Dustin wrote:I can't imagine it not being OK (from a technical standpoint, for instance, how else would one determine for sure a drag is coming from the transmission) to put a car in neutral while driving, and I would think if it is OK to drop a vehicle in neutral at 60mph driving down the road that it should also be OK to tow it down the road in neutral to 60mph as well. That said, I don't understand how towing with the rear wheels on the ground and the transmission in neutral can cause damage, but my manual says it can, as do many posts in this forum.
Classification: GI99-002e
Reference: ITB99-014e
Date: August 8, 2008
LIMITATIONS ON FLAT TOWING OF INFINITI VEHICLES
This bulletin has been amended to apply to all current production models. Please discard all earlier versions.APPLIED VEHICLES:All Infiniti
APPLIED DATES:1992-2009
SERVICE INFORMATION
This Bulletin contains important guidelines and limitations concerning towing of Infiniti vehicles with all four wheels on the ground ("flat towing").CAUTION: Failure to follow these guidelines can result in severe transmission or drivetrain damage. For all towing including "emergency towing" procedures refer to the Owners Manual.
1. 4WD/AWD vehicles equipped with Automatic Transmission:
^ DO NOT Flat Tow - doing so will damage internal transmission components.
^ DO NOT use a tow dolly - doing so will damage drivetrain components.
2. FWD vehicles equipped with Automatic Transmission:
^ An appropriate vehicle tow dolly MUST be placed under the vehicle's front wheels.
^ Always follow the dolly manufacturer's recommendations when using their product.
3. RWD vehicles equipped with Automatic Transmission:
^ An appropriate vehicle tow dolly MUST be placed under the vehicle's rear wheels.
4. 2WD vehicles equipped with a manual transmission:
^ Always flat tow with the manual transmission in Neutral.
^ Always flat tow a manual transmission vehicle facing forward.
^ Maximum speed while flat towing: 60 MPH.
^ After towing for 500 miles, stop. Start and idle the engine with the transmission in Neutral for two minutes - failure to do so may cause damage to the transmission.
AUTOMATIC TRANSMISSIONTo tow a vehicle equipped with an automatic transmission, an appropriate vehicle dolly MUST be placed under the towed vehicle's drive wheels. Always follow the dolly manufacturer's recommendations when using their product.
