Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Thu Aug 27, 2015 8:32 pm
And the answer is yes, but not very well: RH upper timing cover sits above the engine block, at the plane of the cylinder head/block interface, (RH cylinder head is set back an inch or so rearward, it's timing chain is rear most on crankshaft) also, RH upper timing cover mounts beneath the valve cover, so to reinstall without removing VC means a tight press straight into the slot formed by the valve cover and block, nearly guaranteed to displace RTV sealer, and possibly to screw up the head gasket extension at the above mentioned interface.
So as usual, there is no shortcut here, the right way is to first install upper TC, then valve cover.
Actually, it's probably best to install main timing cover first, then oil pan, then upper TC's, then valve covers.
