rx-7ames »
https://forums.nicoclub.com/rx-7ames-u246482.html
Sun Feb 08, 2015 10:57 am
I have a 2006 G35 coupe with manual transmission. I have only had the car for 1 month. It never happened when I test drove the car but after a few days I started noticing some problems with the clutch pedal. Sometimes the clutch pedal sticks a couple inches from the top. It mostly happens when I am driving the car hard, and sometimes the clutch sticks far enough down to have some serious clutch slipping. I have done a lot of research into this and I see it is a common problem with varying results. The first thing I did was change out the clutch fluid in the reservoir several times to until the fluid was clear. This did not change anything so I bled the entire system using the slave cylinder bleed valve. This didn't improve the clutch's reluctance to always return to the top either. I have read several posts on adjusting the clutch but they are all pretty confusing to me. I'm also not sure that this will solve my problems. Now I am just wondering what I should try next. I don't know if I should replace the slave and master cylinder next, or if I should go straight to a pedal upgrade and try out the RJM performance pedal. To me, it really feels like the problem is in my pedal, but I really don't know for sure. The car is all stock, and I am not interested in adding a ton of modifications. I would appreciate any advice on what to change out next. I don't want to spend $100 on a clutch slave and master cylinder if I might be able to fix my problem with a $250 clutch pedal upgrade. Thanks in advance for any advice.
