If the clutch is slipping, the flywheel is already burnt.SketchyRollin564 wrote:So i knew it wasnt a good thing, but i dont have the money for a new one yet, so i figured as long as i drive normally i should be fine
but i read on a youtube coment on a video of a cobalt with a slipping clutch, that if you keep driving it like that itl burn the flywheel
this true? or is this only if you abuse it?
Rarely does that actually happen though. More often than not the gap becomes too much for the pressure plate springs, its not that its warn that far down, its that the thickness is below spec. Also, sketchy is 16, so Im guessing he used this clutch to learn stick, hence why it is slipping.Warped161 wrote:well it all depends on just how worn the clutch is, if it goes far enought you will run the rivets right into your flywheel. At that point your probably going to be replacing the flywheel as well.
The slipping clutch is putting extra strain on the syncros, and third gear is starting to wear. I would take it easy till you get a new clutch. Also, getting some good gear lube might be a good idea.SketchyRollin564 wrote:another thing to throw out since im on the tranny topic, going into each gear after 4.5k ish, it gets tougher to put it in gear, and when im shifting fast i feel like i have to really throw it in there, as opposed to when im driving at lower rpm, where it usually just goes right in, and also, 3rd gear grinds somtimes when i shift fast (i doubt its a shifting error cause its always and only 3rd gear)
so... what im guessing with what little knowledge i have
the synchronizers are bad, and 3rd gear especially?or maybe it has somthing to do with the linkage?
Hahahaha, no the gear should be fine, your syncro is the problem.SketchyRollin564 wrote:third gear as in the synchro for it? or the gear itself?
how hard is it go get gear lube, and put it on the gears?sorry im such a dumbass lol
would it be a good idea to put new synchros when i replace the clutch?
Ooooh careful there. Please do NOT use GL-5 in your transmission, it must be a GL-4. I recommend Redline MT90.FlatBlackIan wrote:
Gear lube is another name for tranny fluid. Nissan specifies GL-5 gear oil for the transmissions, hence the term, gear lube.
yeah, you'll be fine until it just completely glazes over. unless you have worn the disc though to the rivits, in which case you will tear up your flywheel. just drive like a nun, and listen for any odd sounds down there.SketchyRollin564 wrote:wow, i guess ill skip the synchros till i rebuild the tranny haha
but just to make sure, im fine driving with a bad clutch as long as i keep it civil, right? im done messing around till i get my new clutch, but i still dont want anything to happen where i cant drive it home, cause i need my car to get to school, and i think i finally found a new job which im gonna have to drive to (thank god)
I know i should replace it asap, which im going to, but in the meantime (probably a month), im fine driving the one i have as long as i dont mess around?
no, engaging it in neutral doesnt put wear on it, because its only attaching to the flywheel, with no pressure on it from the trans. yes, stay in fourth until you reach your cruising speed, then hit overdrive.SketchyRollin564 wrote:i live in florida, so hills arent a problem. I park on my driveway if i dont park in my garage, but to get out im rolling down anyways, so thats not a problem.
so dont even accelerate from 40-45 in 5th gear? just leave it in 4th untill im at the exact speed i want to be?
also, does engaging the clutch to put it in netural do anything? or is it only when its catching a new gear?
pull the tranny if you want to see the minimum parts you can get away with. you may be able to just use a disc.SketchyRollin564 wrote:trust me, i want to do it, but i have no money, which is why im trying to find the cheapest way possible, so i can do it as soon as possible
on a local forum sombody is saying i can get a clutch from discount auto for like $30, but its just the disk. How do i know if its the disk thats bad and not the throwout bearing or anything?
then do it all once. its gonna cost some bucks, but it wont be half-***'d. do you have any buddies that have done clutches before? its not a super easy process, its time consuming, requires some special tools, and is not something you want to redo as soon as youre done because its making horrible noises. do it once, do it right.SketchyRollin564 wrote:i wouldnt know what to look for when i pull the tranny
again lol i dont know much about cars, and this is gonna be my first time dealing with any of this. I wouldnt be suprised if when i took my clutch out it was in pieces
