Project "Guenhwyvar" CA18DET S13
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
the red sharpie trick on needles came on good. i need to check and see if mine need it :)
cjmirabal1
Car: Past: 90' S13 fastback
CA18DET powered
Current: 90' S13 fastback
Vh45de powered
splintercell wrote:the red sharpie trick on needles came on good. i need to check and see if mine need it :)
lol the trick is to glide the sharpie over the needle, not color it in like its paper! :mike
splintercell
yeah i was figuring as much...too much ink would cause it to run or bubble up. :bigthumb:
cjmirabal1
CA18DET powered
Vh45de powered
almost done finally, few more things to do, replaced that snapped sensor, filled transmission with Redline mt90..intercooler is set up and intake, the motor idles great and sounds great but its not boosting well, boost is being made, but the bov isnt opening, quite possible i have vacuum lines wrong but idk were to go from there, bov isnt recirculated yet, nor is the boost controller connected...not sure
RS style bov(for now, not a fan of rs but its temporary and got was given to me)... gotta figure out how to recirculate it now
replaced the iacv, now it idles sooo much better
unfinished fuse box relocation lol
umm yeah dont know what this is?? help :wtf2:
ill get all matching couplers one day lol
USsil80
that is the stock boost sensor.. IIRC
deuce4Oh
Car: 1991 sil-camino,1985 AE86
wouldn't run full synthetic on that age motor.Stick to the Dino oil
cjmirabal1
CA18DET powered
Vh45de powered
So today was a great day on the swap that ended horrible! lol
almost figured out my vacuum situation, turns out my RS BoV wasnt opening, so we opened it up :ohno: and the f*** had 2 springs! which made it impossibley stiff! took one out...hook it up and reved then all of a sudden! PSSTTTHHH! and we got booost! lol awsome feeeling! so we are adjusting it a bit, it isnt recirculated yet but it isnt affecting idle at all like i thought it would, but im still gonna try to recirc it!.......wen BOOOOM! the f*** clutch fan flew off into the yard next door! like 30 FEET! tore of the pulley and adapter to water pump, wrecked my fan shroud and sank my heart into my arse!
needless to say tomorrows paycheck is gone already! but i already found the pulley on nico and its on its way, im gonna run electric fans now and i get a hook up cuz my mechanics wife works at pepboys!
and my boost gauge cracked wen the fan flew off (fell out of my hand wen i ducked) so im gonna order a prosport elec one!
:facepalm:
filter came in!
painted window handle back to black...soon no more ricer red
installed jdm ignition ring!
took off the cracked spoiler! gonna fill the holes later
damage from the flying fan! wish i took a pik of the hole in the lawn it left! lol
cud of been so bad, and 4 of us were near and all dodged it... and i flew 8 inches above my mech's evo mr!
splintercell
glad nobody got hurt...that thing was like a ninja star cutting everything up in its way.
cjmirabal1
CA18DET powered
Vh45de powered
splintercell wrote:glad nobody got hurt...that thing was like a ninja star cutting everything up in its way.
thats what i thought!!! me and my mechanic are kung fu teachers and we thought that we were under attack from another school for a sec! lmaooooo (insert karate chop smiley here!)
ciscos13
Car: 89' 240sx hatch, s13 sr
the fan must have not been bolted on right. when i bolted my fan it took me nearly 40 mins just turning and turning little by little until none of the bolts could turn anymore. i thought i was done then somehow the other bolt kept turning, then the next.... lol. i recomend staying with the clutch fan rather than the electric fan. when i ran the electric fan, my car somehow felt slower idk.
cjmirabal1
CA18DET powered
Vh45de powered
ciscos13 wrote:the fan must have not been bolted on right. when i bolted my fan it took me nearly 40 mins just turning and turning little by little until none of the bolts could turn anymore. i thought i was done then somehow the other bolt kept turning, then the next.... lol. i recomend staying with the clutch fan rather than the electric fan. when i ran the electric fan, my car somehow felt slower idk.
it wasnt the bolts, the fan flew off witht he pulley still tightly attached!! lol it actually was probaly the water pump piece that came loose somehow, defect probaly..... gonna try to neatly and safely weld it on so no more sliding off! but if that throws off balance to much ima have to suck it up and spend another 70$ and hours of back tracking to replace it.... we will see
splintercell
thats weird...clutch fan robs horsepower not electric fans.
ciscos13
its maybe because i have a honda optimal battery. other than that have no idea why.
cjmirabal1 wrote:it wasnt the bolts, the fan flew off witht he pulley still tightly attached!! lol it actually was probaly the water pump piece that came loose somehow, defect probaly..... gonna try to neatly and safely weld it on so no more sliding off! but if that throws off balance to much ima have to suck it up and spend another 70$ and hours of back tracking to replace it.... we will see
oh, thought was just the bolts lol.
cjmirabal1
CA18DET powered
Vh45de powered
Just ordered a replacement water pump pulley, Prosport blue faced boost gauge, and greddy rs bov recirculation piece!
should be getting my electric fans tomorrow as well.
Gotta love payday! lol
lilRillo
Car: S14 Kouki SR20
Sweet build man! I like seeing the CA get put to use haha and NJ ALL DAY!! im actually kinda close to clifton, do you go too any meets?
cjmirabal1
CA18DET powered
Vh45de powered
lilRillo wrote:Sweet build man! I like seeing the CA get put to use haha and NJ ALL DAY!! im actually kinda close to clifton, do you go too any meets?
were u from? and nah i dont go to meets cuz the car has been down for so long.....if u noe of some here or close by let me know so i can debut the car wen its done! :mike
cjmirabal1
CA18DET powered
Vh45de powered
im still waiting on the seats to come in, gettin a bit antsy for them, havent heard from the seller in a few days :ohno:
cjmirabal1
CA18DET powered
Vh45de powered
my prosport elec. boost gauge came in and so did my greddy bov recirc piece! still waiting on the w.p pulley and s14 seats thou
smoked when off...blue/white when on
now i can recirculate my bov! just gotta figure out a good place to recirculate it into....any suggestions??
ciscos13
cjmirabal1 wrote:my prosport elec. boost gauge came in and so did my greddy bov recirc piece! still waiting on the w.p pulley and s14 seats thou
well usually its recirculated back into the intake but your bov is on the cold side.
cjmirabal1
CA18DET powered
Vh45de powered
yeah thats why im a lil vague on were to connect it to....
splintercell
id put the bov back on hot side...will make easier to plumb back into intake. i ran my sard r2d2 both ways and never noticed any difference.
cjmirabal1
CA18DET powered
Vh45de powered
splintercell wrote:id put the bov back on hot side...will make easier to plumb back into intake. i ran my sard r2d2 both ways and never noticed any difference.
ive heard that r2d2 is a beast of a bov! :bigthumb:
splintercell
it would scare animals and small children :lolling:
cjmirabal1
CA18DET powered
Vh45de powered
[/quote]ive heard that r2d2 is a beast of a bov! :bigthumb:[/quote]
it would scare animals and small children :lolling:[/quote]
niccce!!!!!!!!!!!! hmm maybe i should have a talk with my wallet on getting one of those! alot of my set up is only temporary so i can get the car on the road finally! alot its gonna be changed including bov and intercooler piping and boost controller etc etc
cjmirabal1
CA18DET powered
Vh45de powered
got a lil further in the swap.....friday i finally get to fix that pulley
intake is all done!
new dual electric fans.... gonna run one to a temp sensor and the other to a switch via relay in the drivers cabin so i can turn on wen temps climb
battery box and relocated to the hatch! thing is sturdy and the optima fits perfect
bad angle of fuse box tuck
all the body parts are back on...fixed the front bumper...can hardly notice it was dented!
gotta paint the hood or get a CF one...haven't decided yet! :dblthumb:
cjmirabal1
CA18DET powered
Vh45de powered
so its been over 2 weeks since i ordered my s14 seats, yet i havent heard a word from the guy since i sent payment!
not a email or pm or comment! zippo!
so i filed a claim with paypal...lets see what happens :facepalm:
USsil80
cjmirabal1 wrote:so its been over 2 weeks since i ordered my s14 seats, yet i havent heard a word from the guy since i sent payment!
sorry to hear about that.. if that doesn't work out, i have a set of corbeau reclining seats with brackets for a s13 i would let go cheap... hopefully you get your money back or the seats... was the guy you sent the money to a nico member?
cjmirabal1
CA18DET powered
Vh45de powered
yeah he is a member on nice ("s14menace")......i really want s14 seats, i have nismo reclinables now, but hey send me a pik of urs anyway, who noes they might catch my fancy
splintercell
let paypal take care of his a**. ive always got my money back from flakers through paypal.
cjmirabal1
CA18DET powered
Vh45de powered
splintercell wrote:let paypal take care of his a**. ive always got my money back from flakers through paypal.
yea dats wat im hoping
