I got the factory install guide, and the nissan footwell lights only tap 3 wires, all from the bcm.
The install guide doesnt say what everything does, but I have it figured out!
BCM #63 brown : Domelight Supervision Wire (-)
BCM #11 dark blue: ignition acc or on
BCM #57 light green: interior +12v
So, what I have right now is #57 tired to my led +, #63 goes to a dpdt center off toggle which I put in an empty slot by the dimmer/mirror controls. I picked that switch because it allows me to use one switch position for always on, and the other to door, plus the center off, so I have pretty much any setup I want! I did not use #11, I dont really see why I care about that one.
I built everything from scratch using wire, component board, leds, quick connects, project enclosure. So far I only have the drivers side done, but I made the enclosure modular so I can just plug in each set of lights as I finish them here and there. The led boards Im making could be a bit brighter, but its the door/dome function Im proud of.
The BCM is behind the glovebox.
I say bottom/front because its on the bottom when the plug is plugged in, and in the front when its not! sorry I didnt take a pic before I modded it.
This is where the factory kit says to put the ground. The door function uses the brown wire, but I wanted to be able to have them always on so I put one here as well.
I saw someone else say they ran the wires across the front in a grove, this is the other option.
I wanted to use an illuminated rocker switch, but I could not find one with 3 positions, so then I considered using 2 rockers, one for on/off and one for door/no door. I went with this one and dremeled out the spacer so I had room inside for stuff. I may go back at some point and dremel out holes and illuminate so you can be labeled
At this point the enclosure is fairly unnecessary, however, I did it for 2 reasons, it allows me to make the setup modular, so all I have to do is make new led boards down the road and plug them in. It also gives me a place to house an audio sensor, because I am very tempted to make it sound reactive, just for fun.
This big box fits perfectly up by the fusebox with no issues. I need to go back and finish adding plugs...
This little guy only cost about 3 bucks to make, and it looks pretty good when on.
I extended the circuit to include all the extra dash lights I added
and all the vents
and finally the cup holders, from above
Well that was fun, I hope this helps somebody!
