That's what I was just going to say. You don't even need to weld the fitting on, just drill the hole slightly smaller then the size of the fitting and use a fat rubber oring between the fitting and the pipe for a solid vacuum seal. Two nuts will secure the fitting in place, one on the inside one on the outside.biggie wrote:Can just drill the kit and fit a nipple.
