I have the entire intake off upper and lower runners.
I have been cleaning the valley up.
I am replacing knock sensors and all the vacuum hoses.
I broke the wiring harness for the knock sensors.
Does anyone have a part # for the knock sensor wiring harness?
Can I use this aftermarket harness?
http://www.ebay.com/itm/Knock-Sensor-Wi ... 95&vxp=mtr
Any tips for getting to the rear bolts closet to the strut tower on the valve cover? I can't seem to get to it from any angle.
The A/C idler pulley is discontinued. Mine has a noisy bearing 630ILU NTN is stamped into it, but this also seems unavailable. Where can I get a new one?
Pretty sure I damaged all of my injectors during removal DOH! Any source on reasonably priced replacements? I am confused by the options I have seen, does the q45 use different injectors in each hole?
