allensteiner »
https://forums.nicoclub.com/allensteiner-u79163.html
Fri May 30, 2008 12:59 am
i got my cluster out and it was a pain in the ***...the write up is for a 95 max so might be slight diferences.with the steering wheel tilted all the way down:1) get 2 top screws out of the bezel, pull it out.2) pull off the plastic cover from under the steering wheel, you'll see a metal cover with 2 10 or 12 mm bolts3) take that off and remove the screws from the plastic steering column - the top and bottom ones over the turn signal switch - and remove those.4) remove 3 screws on top of the cluster, pull it out slightly and undo the wiring harness plugs and wiggle it out.
i don't know if your's comes with led's - doubt it. any parts store can order you any color bulbs you want - if they don't stock them pre-order before you get the gauges out.
