Installing Bee*R power builder on R34
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
Arby's
Car: 99 R34 Skyline
05 G35 coupe M6 -non revup swap
92 240sx coupe -RB25 swap
I did try to search could not find previous post on this so sorry if I missed it.
I have an R34 with RB25det NEO motor. just recently purchased the Bee*R launch control or power builder box for it. now I am from the states and this item came from Japan. directions look a little dicey. I havent really dug into the car yet but before i did i wondered if anyone else has done this on this car or similar set up. directions they sent me are for the KA and SR motors... nothing on RB.
thanks in advance for the help
Arby's
Car: 99 R34 Skyline
bump for some help? :)
Car: 58 L210, 63 Bluebird RHD, 64 NL320, 65 SPL310, 66 411 RHD, 67 WRL411, 68 510 SR20, 75 280Z RB25, 77 620 SR20, 79 B310, 90 S13, 92 SE-R, 92 Silvia Qs, 98 S14.
Hold tight, I have a couple people who may know. Tough one for sure, though.
Arby's
Car: 99 R34 Skyline
ok man thanks alot
Arby's
Car: 99 R34 Skyline
find anything yet AZhitman? having troubles find anything i can understand lol
Arby's
Car: 99 R34 Skyline
nothing????
Arby's
Car: 99 R34 Skyline
well i got it hooked up. red light is on when ignition is on. everything at 0 and car runs. but did not rev limit at 2500 like directions say when everything is at 0. turned gain to any setting and car turns off.... any ideas? put green wire on PIN 46 like everyone says, yellow on 44 and then tried 45 like everyon said.
any ideas
Arby's
Car: 99 R34 Skyline
switched mygreen and yellow wires, runs fine like before. but when i turn gain to any setting now it rumbles the rpms and wont let me rev past 1000rpms no matter what the rev limiters are set at
Mattc1994
Car: Skyline
Hey just started reading now. Iv just done the same as you have tried but with my setup I have tried pin out 44+45 they join the further down the loom on a brown block
Mine goes alright
I've down it on a 20e before and worked way harder
I'm just wondering if you have managed to do it a different way and worked differently ie.better???
joshbarnes
Car: 2000 Nissan Skyline R34 GT
Mattc1994 wrote:
Sat Oct 17, 2015 9:28 pm
Mine goes alright
Hi,
Sorry to start an. old thread but I have bought a Bee R rev limiter ( I know they break engines, its just for a one off event) and I'm having some serious troubles wiring it into my R34 Gt (NA). So far I have my my yellow wire connected to pin 44 and 45 (tried both) Green is Connected to 46 and my power and ground wires are correct. The car starts and Runs with this set up but does not limit revs regardless of gain or rev 1/2 settings. Ive tried switching the the green and yellow wire and the car would only start if gain was set to 0 and as soon as gain was 1 or more it would stall. Has anyone else had this problem? if so how did you over come it.
Im wondering if that brown block that pin 44 and 45 join to has anything to do with it?
Thanks
Return to “GTR Forum / Skyline Forum”
