I got the bar 2 days ago in the mail and got some time to install it today and take a test drive.
First the install pictures, it took me about ~30 min, including lifting up my car on both sides in the front, and working at a slow pace. Install is easy, if you know how to remove 2 bolts, and put them back in, this is how simple it is.
Here it is not installed:
The bar itself is installed between these 2 bolts:
And here it is all installed:
I did not have any antisieze left so i just put some high temp grease on the bolts which works fine, i have used it on other underbody screws/bolts.
Torque them back to 97-108 ft lbs, take a test drive, check to make sure they are torqued again.
and onto the results, i have a drop as most of you know, many people dont believe how well this tank of an SUV handles until i actually take them for a ride in it.
Before on the highway my steering wheel would shake a little bit back and forth while driving on the highway if you let it go, now there is no shake, and it doesnt budge, the steering feels more like it is on rails and goes where you want it to go, not to light nor to hard, just perfect. I also notice when i drove over uneven surfaces on the roads that i would get shake side to side, which i didnt mind considering im dropped and these springs are a little harsh, but i dont mind it. Now that shake is gone, you only get like a forward and backwards shake which is normal anyways. Also when you brake it feels more stiff and definetly more planted. I did take it through some curves which i remembered the speeds i usually took them pretty hard with, and now those speeds feel like less and i can go faster on them and it feels the same way as it did at the lower speed i pushed it before.
So the path handled like it was on rails already, now even more so,
All in all i give it a good investment, its only like $55 wont kill you to buy one, easy to install, and you can tell the difference, gets a 10/10 from me.
Rate/Comment/Questions etc.
